View Filter Override Command PDFs
Is there anyway to get the view filter command to change the display style of georeferenced PDFs?
I like to keep mine set to dimmed but always have to switch to none when I’m plotting, then having to change it back to dimmed to continue working.
I have asked Wyn and Vitalii to look into this to see if there is anything we can do around this - unfortunately Images only have one state and TBC does not change that state or ignore that state while producing drawings. You can multiselect images in the imported files list and then change the state of multiples at the same time, just not from the View Filter Manager or the Advanced View Filter settings. When we add the Image Manager Tree to PDF Manager I will try to make sure that we can change the state of a images easily for you there.
When you print with a PDF in a Dynaview we may be able to add the ability to override the dim setting if we create our own Print to PDF function as a part of our Smart Plot tool also(coming shortly)
