Hello Alan,
I see in your “View Filter Overide Command PDFs” that you make a comment that RPS are looking at a Print to PDF command as part of a Smart Plot Suite - will this be able to create vectorised PDFs?
And will it not “bloat” plots like the current TBC Save as PDF does - my current workflow involves creating PDF by “Save as PDF” then replotting that PDF through Adobe or PDF ( that reduces the size by 1/5 at least usually
In tbc use print to a pdf print Driver like Microsoft print to PDFor Cute PDF. Those drivers let you down size the pi elation of solid fls and images / pdfs to eg 120.or 96 dpi and that is significantly less than TBC standard of printing at 600dpi which is whT boats the standard PDFs that TBC currently generates.
TBC already generates vector.PDFs they just aren’t Layered PDFs.
We will likely have a go at this once Smart Plot releases.
