Image Quality when Plotting in TBC with Dynaview (Paper Space)
Can we adjust the image quality settings when plotting a Plan Set?
I’m assuming that you are asking about the PDF pages you have imported showing in your dyna boxes for plotting. this is locked to the DPI that you originally imported the PDF sheets in.
Good information. I just use RPS PDF Manager to import and align. Do I have to use TBC Import and Georeference to control the DPI?
As of now i think pdf manager defaults at 300 dpi with no control over it. Is 300 dpi not enough to make sharp drafts?
I created a 120x36 Roll Plot. It’s okay.
QTO_San Pedro Phase 03.pdf (6.4 MB)
With TBC not doing large plots. I have just started to use BlueBeam to plot multiple sheets to make a large plot. I always have to remember to turn off the dim in the PDF so it doesn’t plot grey.
On this particular project, match lines weren’t accurate. So I built alignment, attached sheets, and spit out a roll plot for quantity discussions with the design team. They won’t provide much data.
at any reasonable zoom that file looks pretty dang good!
haha. so you’re saying my OCD is showing a little.
