Thickened Edges on Subgrade Surface
Does anyone have a good workflow on setting up concrete thickened edges? Is it doable to set it up using the MSI manager & Identify Site Region?
The Site Improvement Process provides the ability to transition the thickness of the same subgrade stack from onle side to the other over a transition zone area between the two
Imagine 3 parallel rectangles where 1 and 3 have the same stack of materials but different thicknesses, and zone 2 is where the transition occurs - assuming a linear transition in thickness, ie on one side you have Concrete 1’ thick and Aggregate 10” thick and on the other ytou have Concreyte 2’ thick and aggregate 15” thick. If zone 2 is say 5’ wide then the concrete and aggregate will transition from one thickness to the other across the transition zone.
These videos show you how this works
https://community.myrockpile.com/t/applying-subgrades-with-transitional-depths-to-airfield-runways/2432
https://community.myrockpile.com/t/creating-transitional-depth-site-improvements-between-areas/1022
