RPS Command Library - v2026.2 Released
The latest version of the RPS Command Library - Version 2026.2 Released Today (5/12/2026).
Click Here - For the Full Release Notes
Click Here - To Download the installer package
I’ve updated the TML and i’m getting 10’s of syntax errors, and not everything is installing even though it is saying it does. I believe this has happened before when I first RPS but can’t find what to do.
Thanks,
Sounds like you used TML Status.
When we do a major update you need to first use the installer package available from the downloads page on our website.
Close all instances of TBC
Wait at least 30 sec
Install the installer package
Restart TBC
Sign in with your Trimble ID
Open a project
Go to RPS Support and Select Menu Manager
Click Reset RPS Menus
Click Refresh Icons
Try a command
You should now be all.set. you can use TML Status to now keep your library up to dare
