Printing Layer Color White
I am trying to print the color white. Using the print workflow through TBC (Plotbox, Dynaview) all lines that are set to white are printing black. The reason for this is we are also including a background image. We have our drone flight image imported and display style set to dimmed. I would like some of the linework be white when printing to show the contrast.
Make it almost White
That did not work. Still shows up black in the sheet view.
I believe 240,240,240 is the only color “whiteish” it will print. it will revert back to black anything before that.
I second Erik’s suggestion of using color 240,240,240. I’ve done this before for the same reason and it comes out so close to white that you can’t tell its not white.
Good to know! Thanks, Erik.
