Background Map Sheet View
Does anyone know the most efficient way to add the background map to the sheetview? Would I need to create an image with a plotbox and georeference it? Please see attached.
Turn off all your linework and keep on the background image and use capture image. This will create a georeferenced image that you can then reimport and use in sheet view.
What is the method for bringing the image back in in its georeferenced form?
either drag and drop or the standard import command
Thanks, I just needed to pull in the snapshot correctly, this worked great thank you.
