Table White Out
Is there a way to White Out Point Tables? Starting doing redlines and instead of drawing in HCSS. I am importing the plan pdf into TBC and then export with the linework and tables. Well, with so much other text on the plan sheet it is a bit clutter and would like to whiteout the station-offset table.
thanks,
I would place the tables in White Space and then create a dynaview border box around the table and place it separately on the drawing sheet where I have white space - that will give you a better result Frank
I went with drawing a rectangle and then doing a fill setting using color white (I changed the color to 234,234,234 instead of white) . I did try the Dynaview and would have liked the option to do a fill setting to blockout some of the plan markings. Anything with text should have the option for whiteout.
