Smart Plot Command Overview
STEP 07 - Reports and Drawing Deliverables
The Smart Plot command fulfills Step 07 of the Takeoff and Modeling Process.
Step 1 - PDF Management (PDF Manager Command)
Step 2 - Cleanup and Edit (Smart Edit Command)
Step 3 - Digitize / Draw / Create (Takeoff Lines Command)
Step 4 - Elevate (Adjust Linestring Elevation = Smart Elevate Command)
Step 5 - Model (TBC and RPS Commands)
Step 6 - Takeoff (TBC and RPS Commands)
Step 7 - Reports and Drawing Deliverables (TBC and RPS Commands)
Step 8 - Data Export and Data Management for Field Operations (TBC Commands)
The Smart Plot command is part of the RPS Smart Suite Command Library and provides a streamlined workflow for creating professional drawing deliverables from TBC Plan and Profile Views.
Other important commands that will be used in this step of the process include:
RPS Commands
PDF Manager
Smart Draw
Smart Profile
Smart Model
Smart Takeoff
TBC Commands
New Sheet View
Print Plan Set
Grid Style Manager
View Filter Manager
Command Overview
The Smart Plot command provides the ability to quickly create professional drawing sheets from TBC Plan and Profile Views using predefined or custom drawing templates, automated Dynaview creation, and customizable sheet layouts.
  • Draw Frame by Paper Size Ratio - Create a drawing frame at a defined location, scale, and rotation to produce drawings at a specific scale.
  • Select Frame - Select an existing closed boundary or frame to automatically generate a drawing sheet at the best-fit scale.
  • Capture Screen - Create a drawing sheet directly from the current Plan View display.
  • Draw Frame - Define a rectangular drawing boundary in the Plan View and automatically fit the selected area onto the drawing sheet.
  • Drawing Templates - Select from RPS templates or existing project templates with customizable paper sizes, orientations, borders, and title boxes.
  • Sheet Layouts - Configure drawing sheets using Sheet Types, split views, and customizable Dynaview placement settings.
  • Dynaviews - Automatically create scaled drawing views linked to Plan or Profile View content.
  • View Filters - Control the layers, surfaces, images, and other project information displayed on individual drawing sheets.
  • Scale Bars and North Arrows - Automatically add and position scale bars and north arrows on drawing views.
  • Drawing Grids - Apply customized Plan or Profile grid styles, including major and minor grid lines and labels.
  • Sheet Management - Organize drawings into Plan Sets, Sheet Sets, and individual Sheets within the TBC Project Explorer.
  • Printing and PDF Output - Review completed drawing sheets and use the TBC Print Plan Set command to print drawings or generate PDF deliverables.
