STEP 05 - Model
The Smart Model command fulfills Step 05 of the Takeoff and Modeling Process.
Step 1 - PDF Management (PDF Manager Command)
Step 2 - Cleanup and Edit (Smart Edit Command)
Step 3 - Digitize / Draw / Create (Takeoff Lines Command)
Step 4 - Elevate (Adjust Linestring Elevation = Smart Elevate Command)
Step 5 - Model (TBC and RPS Commands)
Step 6 - Takeoff (TBC and RPS Commands)
Step 7 - Reports and Drawing Deliverables (TBC and RPS Commands)
Step 8 - Data Export and Data Management for Field Operations (TBC Commands)
The Smart Model command is one of the key commands in the RPS Smart Suite concept and provides an integrated workflow for creating, managing, editing, and analyzing surface models and Cut / Fill Maps in Trimble Business Center.
Other important commands that will be used in this step of the process include:
RPS Commands
Smart Draw
Smart Edit
Smart Elevate
Volumes Manager
TBC Commands
Create Surface
Add / Remove Surface Members
Add / Remove Surface Boundaries
Create Surface Edge Breakline
Create Composite Surface
Create Planar Surface
Create Corridor Surface
Command Overview
The Smart Model command provides the ability to create and manage TBC surfaces and Cut / Fill Maps through a centralized interface. It integrates surface creation, member selection, surface editing, boundary management, volume calculations, and reporting into a streamlined modeling workflow.
- Surface Creation - Create standard TIN surfaces, planar surfaces, and supported Takeoff / Layer surfaces using defined surface parameters and project data.
- Surface Manager - Organize, select, display, and manage project surfaces through a centralized surface management interface.
- Surface Type Filters - Filter surfaces by type, including Normal Surfaces, Takeoff Surfaces, and specialized surface models.
- Surface Groups - Organize surfaces into customizable groups based on surface type, project phase, revision, or intended use.
- Surface Styles - Apply predefined or customized surface display properties, rebuild settings, and contour generation options.
- Surface Parameters - Define surface names, classifications, styles, groups, rebuild methods, and maximum triangle edge lengths.
- Categorize Layers - Assign project layers to Original Ground or Finished Design Takeoff surfaces and identify surface boundaries and Site Improvements.
- Layer Group Modeling - Create and manage surfaces using 3D objects organized within selected Layer Groups.
- Surface Members - Add or remove points, lines, and other supported objects used to construct surface models.
- Drape Images - Apply georeferenced PDF images or orthophotos to surface models for visualization in Plan and 3D Views.
- Trim Surface Edges - Remove unwanted surface triangles to clean up surface boundaries and improve model accuracy.
- Surface Edge Breaklines - Create 3D breaklines along surface edges to help maintain the intended surface triangulation.
- Surface Boundaries - Add or remove internal and external boundaries to define surface limits, islands, and excluded areas.
- Build / Rebuild Surfaces - Build individual surfaces or rebuild surface models following changes to their members or properties.
- Cut / Fill Maps - Create difference surfaces between Initial and Final surface models to calculate and visualize Cut and Fill depths and volumes.
- Cut / Fill Color Maps - Apply customizable color schemes to display Cut / Fill depths, Rock Cut depths, or As-built surface tolerances.
- Shrink / Swell Adjustments - Apply material shrinkage or swell factors to adjust calculated Cut quantities for earthworks planning.
- Loose Haulage Calculations - Calculate adjusted haulage volumes using material bulking factors.
- Surface and Volume Reports - Review surface properties, areas, elevations, triangle counts, Cut / Fill volumes, net volumes, and estimated balance depths in the Results Pane.
- Duplicate TIN Surface - Create independent TIN surface copies without dependent object relationships for use in machine control and field operations.
- RPS Settings - Configure reusable Surface Groups, Surface Styles, Cut / Fill Map Styles, legends, and labeling settings to maintain consistent modeling standards across projects.
