Smart Edit Command Overview
STEP 02 - CLEANUP AND EDIT
The Smart Edit command fulfills Step 02 of the Takeoff and Modeling Process
Step 1 - PDF Management (PDF Manager Command)
Step 2 - Cleanup and Edit (Smart Edit Command)
Step 3 - Digitize / Draw / Create (Takeoff Lines Command)
Step 4 - Elevate (Adjust Linestring Elevation = Smart Elevate Command)
Step 5 - Model (TBC and RPS Commands)
Step 6 - Takeoff (TBC and RPS Commands)
Step 7 - Reports and Drawing Deliverables (TBC and RPS Commands)
Step 8 - Data Export and Data Management for Field Operations (TBC Commands)
The Smart Edit command is one of the “Big 5” commands in the RPS Command Library and a foundational command in the RPS Smart Suite concept.
Other important commands That will be used in this step of the process include
RPS Commands
CAD Cleanup
Convert to Linestring
Crop Crossing
New Layer
Relayer
Isolate Layers
TBC Commands
Project Cleanup
Track Region
Shrink Wrap
Command Overview
Smart Edit provides the ability to carry out all of your data editing needs in a single command and benefits from all of the Smart Suite command special treatments - Click Here for more details on Smart Suite command benefits.
Smart Edit provides multiple ways to
  • Break Lines
  • Join Lines
  • Trim / Extend Lines
  • Fillet / Chamfer Lines
  • Insert Segments in Lines
  • Remove Segments from Lines
  • Edit Lines both Horizontally and Vertically
  • Fix Surface Model Flags
