Smart Draw Command - Overview
STEP 03 - CLEANUP AND EDIT
The Smart Draw command fulfills Step 03 of the Takeoff and Modeling Process
Step 1 - PDF Management (PDF Manager Command)
Step 2 - Cleanup and Edit (Smart Edit Command)
Step 3 - Digitize / Draw / Create (Takeoff Lines Command)
Step 4 - Elevate (Adjust Linestring Elevation = Smart Elevate Command)
Step 5 - Model (TBC and RPS Commands)
Step 6 - Takeoff (TBC and RPS Commands)
Step 7 - Reports and Drawing Deliverables (TBC and RPS Commands)
Step 8 - Data Export and Data Management for Field Operations (TBC Commands)
The Smart Draw command is one of the “Big 5” commands in the RPS Command Library and a foundational command in the RPS Smart Suite concept.
Other important commands That will be used in this step of the process include
RPS Commands
CAD Cleanup
Convert to Linestring
Crop Crossing
New Layer
Relayer
Isolate Layers
TBC Commands
Project Cleanup
Track Region
Shrink Wrap
Create Rectangle / Rectangle 3 Point
Create Circle / Circle 3 Point
Create Boundary
Create Polyline
Command Overview
The Smart Draw command provides the ability to digitize / draw 2D and 3D linestrings including Arc and Straight Segments, 3D nodes and VPIs including the following controls
  • Auto close
  • Extend vertical
  • Override segment length
  • Extract elevation from surface - drape at nodes and or vertices
  • Extract elevation from 3D objects
  • Apply elevation formula to reduce data entry for elevation values
  • Draw n point lines where n is user definable
  • Auto Pan
  • Add line to surface on completion
  • Reverse line
  • Show line direction
  • Grip edit lines while command is running (G hotkey)
  • Start a new line (N hotkey)
  • Vector snap On / Off (V hotkey)
