Good Morning from the UK!
I Just tried to use the RPSSiteImprovementLegend, which always works flawlessly, however this morning it is not asking me for a licence to use this?
I assume this has now changed?
Thanks
Thanks
Same problem here. None of our Unlicensed work, they all ask for a license.
All
as of Jan 1 all unlicensed commands are no longer supported by Rockpile Solutions. We continue to support and develop our own versions of those commands and have decided for a variety of reasons to do the following
We have stopped supporting what were unlicensed commands for the following reasons
We hope that you can understand our position on this issue, and we hope that you can see your way to purchasing Smart Start or a Toolbox or Command Library. If you don’t see any value in the products and services that we provide, we will be sorry to see you go for sure, and will welcome you back any time as a user when you feel that we do provide some value to you and your business.
We are here to help.
If you would like to discuss this with me directly feel free to call me on 720 323 0481
There will be a new Menu Configuration in the next update that we release that will replace the Unlicensed Commands menu, that will be fully supported in Menu Manager.
Menus will now include
The full list of commands included in RPS Smart Start can be found here
| Smart Start Menu | RPS Support Menu |
| Project Files | TML Status |
| Show Direction | RPS Settings |
| Copy Layer Group Members | Project Files |
| Convert to Linestring | Voice Command |
| Quick Line | Line Marking Manager |
| Insert Segment | Show Direction |
| Linestring by Station | Menu Manager |
| Lines to AOI | Toolbar Manager |
| Divide by Slope Distance | Shortcut Manager |
| Explode Solids / IFC / BIM Objects | Text Style Manager |
| Filter by Alignment | Modify ASCII File |
| Station / Offset Points | Getting Started |
| Point Detail Report | Rockpile Website |
| Points to Station | MyRockpile Community |
| Points to Arc | MyRockpile Library |
| VPI at Elevation | MyRockpile Training |
| Name by Layer / Layer by Name | Rockpile Linked In |
| Assign name from Inside Text | Rockpile YouTube |
| Add Isopach | Rockpile Instagram |
| Combine Surfaces | Rockpile Support |
| Offset Surface | Rockpile Contact |
| Trimble Explode Surface | |
| Points to Grid | |
| Surface to Grid | |
| Surface to Points | |
| Explode Lines | |
| Increment Text | |
| Track Line Edge | |
| Edit Alignment as Spreadsheet | |
| Offset Slope | |
| Slope Slope Intersection | |
| Best Fit Linestring | |
| Find Surface Area | |
| Grid Volumes by Boundary | |
| QA Road Lines | |
| Site Improvement Legend | |
| Adjust Area | |
| Compute Lot Setback | |
| Points to Cloud Report | |
| Point Cloud by Boundary |
Thanks
