Phased Earthwork Reporting – Best Practices?
Hey Rockpile fam :construction_worker_woman::construction_worker_man:,
I’m running into a challenge and wanted to see how others have tackled this.
I’m working on a project where the GC requested earthwork reporting to be broken into multiple phases after the full takeoff was already completed. I’ve already built my takeoff in one shot, but now I’m tasked with generating a cut/fill report broken out by Phase 1 and Phase 2.
Here’s what I did:
  • I used AOI boundaries to split the project by Phase 1 and Phase 2.
  • Ran the Volume Report (Grid = 5.000 ft) in TBC.
  • Got some usable totals by phase, but the report still includes bleed-over areas between phases — meaning some scope within the phase boundaries wasn’t calculated cleanly.
What I need to get:
  • Demo scope quantities
  • Mass grade cut/fill totals
  • Subgrade and paving breakouts
Have any of you had success generating clear phased earthwork reporting after takeoff? Is there a better way to cleanly isolate the volumes and avoid mixed results in shared/overlapping areas?
I’d love to hear:
  • Any workflows or settings that helped you get better phase breakouts
  • Tips for structuring AOIs more cleanly
  • How you present phased results to the GC when TBC’s output is muddy
Any input or screen grabs would be gold. :folded_hands:
Thanks in advance — hoping to learn from your experience!
— Falicia
I’d say from my perspective you’ve done it the way I would have. If you just need earthwork numbers, I prefer to use volume manager as it creates the separate cut fill maps for all the phase report regions.
as for overlapping areas it’s super hard to not have any of these in you AOI as 2 lines that sit right on top of each other count as being overlapping, if you have the time after getting all the aoi you offset them inside of themselves by 0.01 that would clean up the overlap assuming they are sharing a single border. keeping naming conventions as short and sweet as possible will help with the reporting. anything I’m sharing outside of myself I generally spend a bit of time formatting it for others consumption
Nudge works fantastic for these tasks.
Can i nudge to the inside, assuming I have a phase land locked by other phases?
you can nudge both left and right of the line as well as ahead and back along the line.
more about the command here: Nudge Line / Nudge Node Command
Nudge is handy for all sorts of various tasks and allows for movement by node instead of the entire line.
You really don’t want to have anything in the “Remaining Area”, instead you want to make another AOI (it could even be called Remaining Area lmao). The takeoff report will not include any of the site improvement material quantities in the totals that are not part of an AOI, if you chose to use AOIs. It seems like a pretty big error in the report to me, but I am assured that is how Trimble meant for it to work. Good luck!
This will be quick. I have done my take off for the beging as OG and Design. Then for phasing, on the OG. I would create my detour if any and combine the OG with the detour. I would have my design join slopes to match the new OG. Its a bit painful but I was picky for Qty on the phasing. I never dealt with the AOI tool for this.
When you apply AOIs if there is unaccounted areas they should report as Remaining Areas, they added that to the reports for this specific region.
In the new tools we are releasing soon, we take care of the 0.01 offsets automatically in Smart Feature when you use the region track or shrink wrap functions.
If your phases overlap, then the only way to separate out the qtys is by applying a phase attribute to the objects that belong to phase 1 or phase 2 etc. And then report and sort by phase attribute - that is what we have added into Smart Feature when it releases.
Our Smart Takeoff command provides more sophisticated volumetric calcs along the lines of what we are already doing in our Volumes Manager command, and now we have the base platform created we can adjust to better meet your needs going forwards.
