Multiple dynaview content boxes and view
April 28, 2025 - How do I stop dynaview boxes and content frame from showing in my plan PDF’s when I have more than one box in the plan view?
I am trying to create a plan set with multiple pages and different scales, but have overlapping dynaview frames, so when I print to PDF I have dynaview frame lines across my plan view. I have tried changing the layers but end up loosing my content.
We use two layers, one with the dynaview line called Dynaview Lines (Do Not Print) and one called Dynaview Views (Print). Then in layer manager, turn off the print box for the dynaview lines. Put all the strings in the Do Not Print layer and actual dynaview content in the Print Layer.
You will have to separate the layer of the frame and the dynaview. Keep the Dynaview layer turned on and the frame layer off.
Thank you that worked.
