Multi Offset Settings
Hello. I am trying to use the multi offset tool for a number of islands on my project. I have the elevation for the face of curb (gutter). I am getting a lot of flags at the radii. Am i missing a setting somewhere?
Change the Point Creeator Settings to RPS Offset Lines not RPS Sideslope Lines.
Those may need tweaking because you are only offsetting 0.01 for a 0.5 elevatioopn delta - but try the defaults and then see if that works, if not you need to change the Interval Settings to Curve to Chord rather than intervals and use 0.01 as the curve to chord tolerance - that should fix it.
Thanks Alan. That worked!
