Multi Offset Glitches
I’ve been using multi-offset a lot on my current project, and about 1/4 times I run the command, it does some weird stuff at external corners. Here’s a snip:
Does anyone know why this would be happening? I can’t seem to find a common denominator between the cases that it happens.
Maybe that the line is overlapping within itself and needs to be trimmed.
I thought so too, but I’ve gone through the lines and they all segmented properly with no overlaps
These types of issue can be caused by either point creator settings or the spacing between nodes on the source lines.
There may be other causes also we would need the lines and the settings that you are using to track this down
