Multi-Offset Line creating line loops?
Any setting suggestions to remove the creation of these loops in the FL and Lip?
I would double check your source line geometry, does it bound back on itself through there and that is the potential cause?
It’s hard to say for sure without taking a look at the data. If you want to post the data we can take a look and let you know what we see.
Shane the corner of the originating line doesnt double back on itself, the originating line is a clean single point corner. It’s odd to me that there are a handful of these in this job but only a couple do this even though the lines the same everywhere. I’ll attach the original CAD files to this post. The lines in question are the turnout/parking pocket TC lines along various streets.
673-135_MSTR PH 1.dwg (982.4 KB)
673-135_MSTR PH 2.dwg (917.9 KB)
673-135_MSTR PH 3.dwg (889.6 KB)
Sometimes the point creator generated interpretation points can clash with the nodes on the source lines - try knocking your interval setting off a round number and see if that helps.
