I just updated PDF manager and now I’m getting this zooming error when I try to import a sheet. The zoom jumps in and out. Once I zoom in far enough, it stops jumping so its still useable but frustrating. I’ve attached a video to show the error. Is anyone else having this issue?
I’ve experienced the same as well. To your point it worked again once zoomed in far enough and the vectors still snapped to the right place. Just couldn’t be zoomed at a certain distance, only either very close up or very far out.
I have seen this as well. Kind of a pain but I usually can work with it. I can’t tell what exactly causes it as well.
We have seen this but something appears to trigger it as it doesnt seem to hapen all the time. If anyone can nail down the root cause of it please provide more feedback so that this defect can be correced.
Appreciate any help you can provide on this one.
Can’t figure out what caused this to trigger but once it happened on the first project the same thing happens on every project I am working on.
An additional glitch has happened as well: When I have a PDF in the background, zooming with the mouse wheel below a certain size cause the PDF background to disappear. It re-appears by zooming back up.
I took a screen recording.
Marshall
Are any of you using share drives while you are working, it could be a SHare Drive issue that locks the PDF derivitive files that get created in the project File as you Georef the Sheets - if File Locking happens while you are doing that (by the Share Drive systems) then it could be that the .ovr files are not getting created correctly.
Try Support - Options - Advanced, Override DIRECTX to OpenGL2.
I find that DirectX has a lot of issues with PDFs that seem to disappear when I use OpenGL2 as the override.
The glitching as you zoom in and oiut, we have seen it but as yet have not found a way to fix it, i use OpenGL2 all the time and have not really seen it on my machine, if you can try OpenGL2 to see if that fixes it let me know the outcome.
Alan: I switched to OpenGL2. Rebooted. No change, still the funky zooming.
But, yesterday I got a revision to the same PDF and used PDF Manager as usual. No issues with the revised PDF’s zooming. I keep trying to see what might be triggering the zoom issue but, so far, it works.
I’ll keep on it…
Marshall
Ity could be a Blue beam issue they do funky things to PDF files when they separate them
I noticed this issue for the first time today.
Note sure if it matters, but in my instance, I started to Insert the image clicked a few points and then closed PDF Manager. Then later when I returned to the image it had the issue. Maybe it only occurs if you had previously started and closed the command…….
I have not tried to duplicate.
I restart TBC and it fixes the issue.
