What are the top 1-3 Rockpile commands you have been using the most lately?
For me that can me tough because there’s a lot to like and certainly a lot to use. If I had to choose right now, it would be.
Smart Draw: Drawing best fit arcs around intersections. Not having to stop when you get to an intersection or curve is so satisfying!
Smart Elevate: Contour Mode. It has made elevating linework fast and fun.
Crop Crossing Lines: This is one I’ve gotten so used to, I’m not sure I remember how to build a model without it. :wink:
Honorable mention: Smart Edit: Model Flag Fixer. How quickly can you fix surface flags now? Big fan. It’s amazing.
This one’s pretty straightforward for me.
PDF Manager has been a huge upgrade, making it much easier to georeference and vectorize pages.
Relayer streamlines the process of moving vector data into the correct layers, ensuring efficiency and accuracy.
Smart Edit is particularly valuable, allowing us to stay within a single tool to break, join, extend, add, and remove segments—making edits seamless and
RPS Copy/RPS Paste I use everyday. Very useful command. Makes life so much easier.
RPS Convert To Linestring is an awesome command…use it all the time.
RPS CAD Cleanup is also used daily. Get rid of those blocks and UCS.
RPS Isolate is my top.
RPS New Layer
RPS Slope designer
Copy/RPS Paste
PDF Manager
Optimize linestrings - Do a lot of PDF Takeoffs.
  1. Convert to Linestring
  2. CAD Cleanup (hoping convert to linestring option can be added into step 2 of CAD cleanup)
  3. PDF Manager
Honorable Mentions: Reverse Line, Offset Slope, RPS Copy/Paste, and Edit as Spreadsheet.
At this time in the project
  1. convert linestring - for owners CAD linework
  2. smart join - for contours and owners CAD lines
  3. point detail report - for bridge beam delta
These are the 3 i use on every job.
PDF Manager - Fantastic and a joy to use
CAD cleanup/Convert to linestring - glad you guys added the vertices count back!
Multi-Offset Line - the convenience of creating an off-set/tie-surface with the linework is so nice.
I’d like to use smart elevate more but i dont think the machine i’m using has the horsepower to make it enjoyable to use. Maybe i need to switch to OpenGL or something and try again.
  1. PDF Manager
  2. Smart Copy
  3. Smart Edit (Smart Join and VPI to 3D only)
  1. PDF Manager
  2. Convert to Linestring
  3. Combine Surfaces
Have you switched the graphics settings in your computer to high performance mode?
1 PDF Manager
2 RPS Copy/ Paste
3Smart Stakeout/ Point Creator.
Trev, you need to elaborate on what high performance mode is and how to turn it on. Never heard of it.
Oh sorry @Thomas_Tomsu . We did a post and video about it here.
https://community.myrockpile.com/t/setting-up-your-computer-correctly-for-tbc/2934
Smart Edit, Smart Draw, Smart Elevate
