All,
I have linework that is currently In INGCS Hendricks US Survey FT and I would like to move this linework to Indiana West. Does anyone Have experience with this?
This was a construction project that was designed in INGCS Hendricks, but the asbuilts are required to be in Indiana West.
Thanks,
Dave
You need northing, easting, and elevation of your control points in both coordinate systems, then use Transform Survey Points. Either create points with lat, long, and height in the second coordinate system, or duplicate your control points using grid-only versus non-grid only and change the coordinate system. I’d get familiar with the process in a junk file or copy before performing the transformation in the real project. Check, recheck, verify! Hopefully you have way to confirm that the transformation produced the desired results (background map?).
If someone else knows a better method, don’t hesitate to speak up!
Thank you for pointing me in the right direction.
