Changing Coordinate systems
We use two different coordinate systems, which TBC handles well. There are times when I need to convert from one system to another. Points convert well but not any of the cad work (lines circles etc). We then use other software to convert the cad files. Is there a way to do this in TBC, or could rockpile add a feature to perform this task.
Phil
I would also like to know this also. I had to do this once where I changed my State Plane system leaving my linework in the correct N,E location. So, all I did was just grab all that unmoved data and use the Move command. Be sure the scale did not change.
You have to ‘transform’ your design data. Commands such as move, rotate, scale, or ‘transform by points.’
