Chris / Noah
Here is the first viideo in which I cover
Using Civil 3D to export LandXML and a Civil 3D DWG file
Importing ythese files into TBC
Importing the source DWG file into TBC and the differences
Using CAD Cleanup and Project Cleanup to clean the imported CAD Data
Using Smart Scene to soryt throygh the imported data and control data visibility
Using the Relayer command to relayer data to your target layers
Using PDF Manager to lay our PDF Plan Sheets and also capture Typical Details as images in the plan view
Using Data prep Tools including
Smart Draw - 2D and 3D Lines, Curves, VPIs and ELevations
Smart Draw to create Rectangles
Smart Elevate - Pad Mode to Elevate Pads
Smart ELevate - Spot Mode to elevate 3D Lines
Smart Elevate - Elevate Contours using Elevate and Contours by Crossing Mode
Smart ELevate - Elevation Edit Mode and Elwvation Editing
Smart Edit - Break Mode
Smart Edit - Join Mode
Smart Edit - Trim / Extend Mode
Smart Edit - Edit Mode
Smart Edit - Insert at Beginning, Insert at End, Insert Auto
Smart Edit - Remove Segment
If you can master these commands obver the next week, you will be ready for Modeling and Takeoff after that
