Importing a Project Template into TBC
I have a project that was setup using the standard US Survey feet template and need to get the Takeoff template into the project. Is there a way to import that with all the layer styles and setup into a different project?
Thanks
Colton
not sure if this is 100% the proper way. you could export the whole job to VLC project Link Export and then import that file into the correct templet.
Yep what Brandan said.
I learned something yesterday!
Go to the layer manager in the project you have the proper layer manager saved and export them. Then go to the project you want them in and import them.
I like both ways mentioned, if you have an extensive template with plan sets and other other pertinent items, do the .vcl but know you might need to standardize to get the OG and FD layers into categorize tabs, if it is just layers you are after do the export from the layer manager in the Takeoff template and import via layer manager into the US Survey foot project you have already drawn in, but know you might need to standardize to get the OG and FD layers into categorize tabs
For layers and layer groups you use TBC Layer Manager and export those into a .layer file that you can import into another project.
For drawing templates i select those and use rps copy to clipboard and rps paste
If you have all the data you can select all Nd rps copy and rps paste between your project and a new project started with the correct template
Thanks Guys. I used the VCL to export and reimport into the correct template file. Only thing I have to do is reimport my PDF files
If you copy all of the PDF image files from the current projects folder to the new projects folder and then select all of the pdf pages from the imported files list and use RPS Copy RPS Paste that copies the references across to the new project then lose and reopen the project the pdf pages should automatically show up in the right place.
The references carry the location and scaling of the sheets as well as a reference to the file names - so provided the new project can find the files needed then they will auto sho up after you close and reopen the project
Hello everyone, Cassidy K here in Australia. I need a little bit of help. I’ve been trying to get this to work and can’t seem to get it there. If I drag my project templet in to the project I am working in it starts a whole new project, but I have no idea what to select to export my sheet templates as a Project VCL. I have updated all my A0,A1,A2,A3,A4 sheet templates and want to import them into older projects without having to export all of my line work. just can’t seem to make it happen. I also have several georeferenced PDF’s and images in the project that don’t stay referenced when exported.
You can select the Plan Sets, Sheets Sets and Sheets in the Project Explorer, and then you can either use RPS Copy to Clipboard and then in the destination project use RPS Paste to place the in the project or you can use Export, Construction Tab, Select Project VCL Exporter to export a VCL of the selected data and then you can drag and drop the VCL file into your destination project(s)
When selecting in the project Explorer - use the CTRL or Shift Key to group select the Plan Sets / Sheet Sets, Sheets you want to copy.
Thank you Alan. Its been driving me nuts.
If, you only plan to use the PDF as check. I usually just use another TBC project just for PDF references. I never tried to export a GEO PDF.
Keep the sheet VCL saved for next project in a good location. I keep adding or making changes to the plot sheets. so, you may end up making changes to your sheets.
