Surface to Grid to Create Lines
The Surface to Grid routine will created points at a defined grid spacing. Is there a routine that will created lines for the grid instead of points, or even both at the same time?
We will shortly be reasing an updated Grid Volumes by boundary command that will generate grid cell lines as well as volume labels per grid cell (cut, fill, balance) - maybe those will do what you need.
