Points to Grid Command
Points to Grid
  • The Points to Grid command is part of the RPS Modeling Toolbox.
  • The command is located in the Surface / Volumes menu group.
Created to support production data from Leica machine control systems, this command allows the user to find the first, last, highest and lowest points in each grid cell from imported data files based on a defined grid pattern (origin, orientation, row and column spacing). The selected data is layered into separate layers so that it can be used to create different surface models.
COMMAND HISTORY
The following video shows how to utilize the Points to Grid command:
The Points to Grid command dialog looks as follows:
Select the point data that you wish to evaluate and organize into the defined grid cells.
Alignment:
Optionally select an alignment to use as the reference for orienting the grid. Leave this set to when an alignment-based grid is not required.
Grid Size:
Enter the size of the grid cells that will be used to group and evaluate the selected points.
Point Options / Layers
Compute Low Point checkbox:
Check this checkbox to identify the lowest-elevation point within each grid cell.
Low Point Layer:
Select the layer on which the resulting low points will be placed.
Compute High Point checkbox:
Check this checkbox to identify the highest-elevation point within each grid cell.
High Point Layer:
Select the layer on which the resulting high points will be placed.
Compute Average Elevation checkbox:
Check this checkbox to create a point representing the average elevation of the points contained within each grid cell.
Average Elevation Layer:
Select the layer on which the resulting average-elevation points will be placed.
Earliest checkbox:
Check this checkbox to identify the earliest point within each grid cell based on the available point data.
Earliest Point Layer:
Select the layer on which the resulting earliest points will be placed.
Latest checkbox:
Check this checkbox to identify the latest point within each grid cell based on the available point data.
Latest Point Layer:
Select the layer on which the resulting latest points will be placed.
Select the points to process, define the Grid Size and optional Alignment, then choose which point types you want the command to calculate. Select an output layer for each enabled result and click OK to process the data.
INPUTS
Select the point data to be processed.
Alignment:
Optionally select an alignment to control the grid reference.
Grid Size:
Enter the grid cell size used to group the selected points.
Point Options:
Select whether to calculate Low Point, High Point, Average Elevation, Earliest, and/or Latest points within each grid cell.
Output Layers:
Select the layer on which each enabled result type will be created.
HOT KEYS
U = Unlock
SHIFT M = Pop Up Menu
X = Start Over
Z = Decrement
C = Increment
HEADER BAR COMMANDS
COMMAND BUTTONS
OK
Cancel
HELP
The following videos show the use of the Points to Grid command in a workflow context:
If you would like to provide feedback on the use of the Points to Grid command or to request enhancements or improvements to the command, please click Reply below.
