Surface Area by Slope Range Command
  • The Surface Area by Slope Range command is part of the RPS Modeling Toolbox.
  • The command is located in the Reports menu group.
Reports the plan and slope areas for Cut and Fill, broken down by specified slope ranges on each of two surfaces. The report uses the isopach computed between the two surfaces (e.g., Existing and Subgrade Adjusted Finished Grade) to determine Cut and Fill areas and then sums the areas of triangles of both surfaces that fall within the defined slope ranges within the computed Cut and Fill areas. Ideal for the determination of surface finishing / trim areas in Fill scenarios.
The command has been updated to fully support the use of Reference Surfaces added in TBC v5.60.
The following video shows how to utilize the Surface Area by Slope Range command:
COMMAND HISTORY
Update Information
The Surface Area by Slope Range command dialog looks as follows:
Original:
Select the first of two surfaces required for the command. This will typically be the Existing Ground surface. The list of surfaces presented will include both local and Reference Surfaces.
Design:
Select the second of two surfaces required for the command. This will typically be the Finished Grade or Subgrade Adjusted Finished Grade surface. The list of surfaces presented will include both local and Reference Surfaces.
The command utilizes the two surfaces to determine the areas of Cut and Fill between the surfaces. Once the Cut and Fill areas are known, the command then sums the planimetric and surface areas of the triangles for both selected surfaces and reports those areas based on a series of slope ranges defined in the next section.
Boundary:
If you wish to select a Boundary to limit the reported information, you can select it here. Currently, only one Boundary is supported.
Cut Slope Ranges:
Create the list of Cut Slope Ranges that you wish to report on. You can enter these in any order, and the command will sort them into a logical sequence from Flat to Vertical. Use the Add, Edit, and Delete buttons to the left of the list box to change, add, or remove slope ranges. On selecting Add or Edit, you will be prompted with this dialog to enter the value at the lower end of a slope range. You can enter slopes as a %, i.e., 2%, or as a ratio, i.e., 2:1 / 1:2.
Fill Slope Ranges:
Create the list of Fill Slope Ranges that you wish to report on. You can enter these in any order, and the command will sort them into a logical sequence from Flat to Vertical. Use the Add, Edit, and Delete buttons to the left of the list box to change, add, or remove slope ranges. On selecting Add or Edit, you will be prompted with this dialog to enter the value at the lower end of a slope range. You can enter slopes as a %, i.e., 2%, or as a ratio, i.e., 2:1 / 1:2.
COMMAND TIPS
HEADER BAR COMMANDS
  • Help - this document access
  • RPS Settings
  • Takeoff Lines
  • Smart Edit
  • Adjust Linestring Elevation
  • Create Boundary
  • Create Surface
  • Add/Remove Surface Members
  • Create Surface Edge Breakline
  • Add/Remove Surface Boundaries
  • Create Quick Contours
  • RPS Paste
OK BUTTON
Executes the command and generates the Excel-style report. Note that while the Report is open, the command is locked, and no other command in TBC can run. The Report will look as follows:
The Report is split into 4 parts: Cut Values and Fill Values, as well as Surface 1 and Surface 2. Each part reports the Plan Area and Surface Area and breaks out the areas into the defined slope ranges.
Values can be copied and pasted from the Report into a full Excel spreadsheet or can be saved as an .xlsx Excel spreadsheet as needed. That file can then be opened in Microsoft Excel if required. The file is typically saved in the Project Folder for the current TBC project.
CLOSE BUTTON
The following videos show the use of the Surface Area by Slope Range command in a workflow context:
If you would like to provide feedback on the use of the Surface Area by Slope Range command or to request enhancements or improvements to the command, please click Reply below.
