Rotate Plan View
- The Rotate Plan View command is part of the RPS Data Prep Toolbox.
- The command is located in the View menu group.
COMMAND REQUIREMENTS
TBC Version Dependency
This command requires TBC v5.51 or later.
TBC Edition Dependency
This command, like all TML commands, requires the Survey Advanced Edition in order to run.
The Rotate Plan View command provides the controls required to rotate and reset the selected plan view using simple rotation controls derived from user inputs, selected line, alignment, or text object, etc. The view can be quickly rotated to maximize the use of your computer screen width or height and improve viewing orientation. The command is especially useful when working with long linear projects or with skewed site plans.
The Rotate Plan View command dialog looks as follows:
Select View:
Because a project can have multiple plan views, select the Plan View that you wish to rotate from the pull-down selection list. If you only have one plan view, it will be the one that is currently selected in the selector.
Direction:
Select the rotation axis that you want to use. The options are:
Right - Uses the horizontal axis of your screen as the reference axis for the screen rotation, i.e., when you select a line segment or text item for the screen rotation, it will be rotated so that it is parallel to the horizontal axis of your screen. This is the most common use case for screen rotation so that you can maximize the width of the screen, or make text on rotated drawings easier to read for the user.
Up - Uses the vertical axis of your screen as the reference axis for the screen rotation, i.e., when you select a line segment or text item for the screen rotation it will be rotated so that it is parallel to the vertical axis of your screen.
Rotation Mode:
Select the rotation method that you want to use to orient the rotated view. The options are:
Free - Select a location and freely pick a rotation angle to rotate the view. You can select two points, or, for orientation, you can snap the end of a line segment using Shift + Click to determine the angle of the line at that end of the segment (note that the end you select will dictate the “Up” direction after the plan rotation is applied). In this mode, when you have selected an angle, press the Enter key or click Apply to execute the plan view rotation.
Re-center to anchor location checkbox:
When checked, the plan view will be automatically recentered on the anchor location point as the view is rotated. The anchor location point is the first location clicked in the angle mode, the station point clicked with zero offset in the reference line mode, and the text insertion point in the text mode.
Reference Line - Select a line or alignment to use as the reference. In this mode you can select a station along the line, which will determine the instantaneous bearing of the line at that location and rotate the view so that that part of the line is oriented left to right across the screen. Note: If the line has its start point at the western end of the line and its end at the eastern end of the line, after the rotation, the line will increase in station from left to right along the line. If the line has its start point at the eastern end of the line and its end point at the western end of the line, after rotation the line will increase in station from right to left. You can repeatedly click different stations along the same line to repeatedly realign the drawing with the selected axis of the screen. In this mode, as soon as you click a station, the rotation of the plan view is instantly applied.
Text - Select a rotated text object and the view will be rotated to make the text align with the selected axis of the screen (vertical or horizontal). The normal use case for this is to use the left-to-right axis (horizontal axis) so that the text is easily readable for the user. In this mode, as soon as you click a text item, the plan view rotation is applied.
Show line direction checkbox:
When the Reference Line method is selected, the show line direction checkbox is enabled so that you can display the RPS show line direction indicators (start and end of line flags and line direction indicators).
RESET BUTTON
To reset the selected plan view to its normal north-up orientation, click the Reset button.
APPLY BUTTON
When you tap Apply, the selected plan view will be rotated and the command will prepare itself for another view or orientation selection and another process execution. If you do not want to make a second selection and repeat the process, tap Close to finish the process.
CLOSE BUTTON
The following video shows how to utilize the Rotate Plan View command:
The following videos show the use of the Rotate Plan View command in a workflow context:
USE CASE NOTES
When screen rotation is in use, the window selection methods remain parallel to the axes of your screen (i.e., the rotated view). The selection windows remain rectangular, with left-to-right and bottom-to-top axes.
When the screen rotation is in use, the input of coordinates like @505@50,@50 still apply to the North and East directions as normal. In a view rotated by 45 degrees, a @50 @50,@50 coordinate entry will result in a point 50’ North and 50’ East of the reference location and will create a point vertically above the reference point in the rotated view.
We recommend that you move the object (text item, line segment, free point rotation center) to the center of the screen or use the re-center to anchor location checkbox prior to executing the plan view rotation. You will find this less disorienting as a user.
If you would like to provide feedback on the use of the Rotate Plan View command or to request enhancements or improvements to the command, please click Reply below.
