does anyone know a fast way to add point at multiple intersecting line locations? or could we add a new key location to the “point creator settting” so adding points at multiple intersecting lines is faster than one by one. here is a screen shot of where I wanting to do. there is more location.
talked with another guy and reminded me of the point by interval. which help. Which points at intersect line would of been a better chose as each of the lines I had. Where at different intervals.
Use create from CAD command - that does it automatically for thousands of lines at once
If you want control over the point numbering - Try using the Point Creator function in the Civ Robotics Manager command in Tool Shed Menu
That tool is like the 20 bucks I left in my wallet and forgot about it for months. Works. just wish I could pick the order the points were numbered.
