Long File Path Names
I came across this setting in Windows Settings today that I was unawre of, this may assist any of you that have issues with loing file path names not being used in Trimble Businmess Center.
Sometimes when you try to import e.g. a PDF File, TBC will not let you because the file path is too long when you take into account all of the Folders, Sub Folders, Network / One Drive etc locations and the filename.
While I cannot say that this setting will fix those issues or not, it may help.
Go to your Windows Start Menu and type in System
Select Advanvced
Find Enable long paths and switvch it On
I cannot tell you what positive or negative impacts that this may have but it may assist you in the above situations.
IT departments everywhere are going to LOVE us clicking on Advanced system settings!
