Im having some issues with the colour banding when using label points. I can get it to produce the height differences between a point and surface however it wont apply the colour banding for the cut/fill. I have noticed there is an additional box from when i last used it next to the tick box for colour banding however it has a red cross next to it with an error.
Things i have tried:
- I made the template approx 18 months ago and was working fine, so i tried to recreate the template and got same results.
- Was using a reference surface so physically imported the ttm into project to eliminate reference surface as being the problem.
- Tried other delta options but same result.
- Checked to make sure i am runnign latest tmls.
