Cross Section Labels not moving
I am setting up a cross section template and I followed one of Alan’s videos on how to set up cross section labels. I’ve created lines, set them to surface, brought them into the corridor, created the node labels and when it comes to creating a kink to offset text automatically, I’m not getting the desired results. I’ve included a screen shot of the issue I’m having. I have the End point created correctly as far as I can tell, so I’m thinking it might be a setting somewhere else.
I’m also having the issue where my decimal points and colons are not showing.
The decimal point and colon issue is a fo t issue with TBC - try changing the font to Segoe UI or another font type. I think many stroke fonts have this issue - true types may be better.
I think there is a defect in TBC relating to the kink lines - I think Trimble broke that a while back because I have seen similar issues in recent versions where kink lines that were working Re no longer working.
You may want to send in a report to your dealer to get that on Trmble’s radar to fix.
