Labeling Profile lines for Sheet View
Working with a profile view of an alignment and corridor. I am currently struggling to get the points labeled with their station and elevations at each point of both separate lines. The current viewport looks like this with what I have set up. The blue text does not show up in sheet view but is the target information.
What I am hoping to figure out is how to get the station, elevation and slopes of both the red and orange line shown in the sheet view. Currently I have tried using drafting text to label them based on horizontal alignment with the code below:
Test
@<S,T,F,2>@
@<ELL,LD,F>@
This gave that bottom right test text, but the issue is that one is labeling the red line’s last station instead of the orange line at station 14+38.36. In theory part of this issue is that the orange line has connection to the horizontal alignment of the red one, but the Leader point still reads exactly what I need. Testing this same setup for the red line results in the same last station issue. I’ve also tested using the vertical alignment as reference, but that results as question marks instead.
If you use our new Smart Label Command you should find that you can label these with no problem.
In profile view Elevation is the Northing value not the line elevation as you are using.
Elevation is the depth in and out of the screen as it is in plan view ie it is like an offset in the profile view.
Smart Label has a set of predefined labels for use in the profile view.
I am not sure that there is a Label that TBC provides using Smart text that can Label the slope in profile view - I would need to check that. Our Label Lines or label slope command has some computed text labels that can possibly do that for you. I need to check and get back to you here.
So, I know this is an old post but i just stumbled across why it not be giving you the data, at least in version 2025.2. As stupid as this is they’ve screwed up on what its actually calling out. If you choose Northing And Easting as the data you want it will show…
@<E,LD,F>@ = Station
@<N,LD,F>@ = Elevation
I’m not sure if they’ve fixed this in the newest version.
