Grid Volume From Boundaries
- The Grid Volumes From Boundaries command is part of the RPS Modeling Toolbox.
- The command is located in the Reports menu group.
Computes the volumes between two selected surfaces and within multiple selected boundaries using the grid volume method. The computations are extremely fast, even with a small defined grid interval. This tool is ideal for rapidly computing volumes on projects as an interim step prior to final results using the TIN surface method.
COMMAND HISTORY
July 2025 - Updated the command to label grid cell and boundary volumes and added the ability to create a point at the centroid of each grid cell for the lowest, highest, or average elevation point. Also enhanced the Excel output to support the new Excel Templates and improve the formatting of the output. Added the ability to apply Shrink / Swell and Loose Haul Bulking Factors to enable reports of Adjusted Cut, Adjusted Balance, and Loose Haul numbers for Cut and Borrow / Waste.
The command has been updated to fully support the use of Reference Surfaces introduced in TBC v5.60.
The following video shows how to utilize the Grid Volumes From Boundaries command:
The Grid Volumes From Boundaries command dialog looks as follows:
Grid Definition
Grid Type:
Select the grid type that will be used for the volume calculations. Available options include:
Orthogonal Grid:
Uses a regular grid oriented according to the defined Grid Direction.
Alignment Grid:
Uses a grid referenced to a selected alignment, based on station and offset.
Grid Direction:
Enter the direction or rotation angle of the grid when using the Orthogonal Grid method.
Volume Grid Size:
Enter the grid spacing that will be used for the volume calculations. Smaller grid sizes provide a more detailed volume assessment.
Volume Adjustments
Apply Shrink / Swell Factor to Cut Numbers:
Check this checkbox to apply a Shrink / Swell Factor to the calculated cut volumes. The adjusted cut volume is used to determine the adjusted Cut / Fill balance.
Compute Loose Haulage Numbers:
Check this checkbox to calculate loose haulage volumes using the defined bulking factor. This provides estimated loose material volumes for cut and waste or borrow requirements.
Report Options
Report Area:
Check this checkbox to include the calculated area of each boundary or grid cell in the volume report.
Save Computed Grids:
Check this checkbox to save the calculated volume grids within the TBC project for future reference and analysis.
Report Volume by Depth:
Check this checkbox to include a breakdown of the calculated volumes by depth in the report.
Volume Labels:
Check this checkbox to generate volume labels at the centroid of each boundary or grid cell. The labels display the calculated Cut, Fill, and Balance volumes. Additional label formatting options may be displayed when enabled.
Create Points on CF Map:
Check this checkbox to create 3D points on the Cut / Fill Map. The command supports creating points at the centroid of each grid cell or boundary using the Lowest, Highest, or Average Elevation, as described in the existing command documentation.
Surface Source
Source:
Select the source of the Cut / Fill information that will be used for the volume calculations. Available options include:
- Select Surfaces: Calculate volumes between two selected surfaces.
- Select Reference CF Map: Calculate volumes using an existing Reference Cut / Fill Map.
Initial Surface:
Select the initial surface that will be used for the volume calculations.
Final Surface:
Select the final surface that will be compared against the Initial Surface to determine Cut and Fill volumes.
When Select Reference CF Map is enabled, select the existing Reference Cut / Fill Map that you wish to use for the calculations.
Boundary Source
Boundary Type:
Select the method that will be used to define the areas for the volume calculations. Available options include:
- Boundary Lines: Calculate volumes within one or more selected closed boundary lines.
- Boundary Grid Cells: Calculate volumes using a defined grid of boundary cells.
Boundaries:
Select the boundary lines that you wish to use for the volume calculations. Each selected boundary will be calculated separately.
Options:
Click this button to access additional selection methods for choosing boundary objects.
INPUTS
Grid Type:
Select Orthogonal Grid or Alignment Grid to define the grid calculation method.
Grid Direction:
Enter the orientation angle for the volume grid.
Volume Grid Size:
Define the spacing used to calculate grid volumes.
Volume Adjustments:
Optionally enable Shrink / Swell and Loose Haulage calculations.
Report Options:
Select whether to report areas, save computed grids, report volumes by depth, generate volume labels, or create points on the Cut / Fill Map.
Surface Source:
Select two surfaces or an existing Reference Cut / Fill Map for the volume calculations.
Boundary Type:
Select Boundary Lines or Boundary Grid Cells to define the calculation areas.
Boundaries:
Select the boundaries to be included in the calculations when using the Boundary Lines method.
REPORTS
The Grid Volume From Boundaries command generates volume calculation reports showing Cut, Fill, and Balance values for each selected boundary or grid cell.
Results pane reports
The results of the calculations are formatted and displayed in the results pane of the dialog.
When enabled, the command can create volume labels, save calculated grids, and generate 3D points for use in the TBC project.
RPS SETTINGS
Use the RPS Settings button in the Header Bar to access the general RPS Settings interface and review or modify applicable settings.
HOT KEYS
U = Unlock
SHIFT M = Pop Up Menu
X = Start Over
Z = Decrement
C = Increment
HEADER BAR COMMANDS
In the Header Bar of the currently operating command, you will see command icons that provide access to other commands that you may need while executing the current command. The Grid Volumes From Boundaries command offers the following commands in the Header Bar:
- Command Help
- RPS Settings
- PDF Manager
- CAD Cleanup
- Smart Select
- Smart Draw
- Smart Edit
- Smart Elevate
- Smart Model
- Volumes Manager
- Create Boundary
- Create Quick Contours
- RPS Paste
- Leader Lines
COMMAND BUTTONS
Apply
Click the Apply button to execute the process and generate the volume reports and grids / labels in your drawing area. On completion, the command readies itself for further execution.
Switch command
The Switch Command button provides the ability to close the current command, close all running commands, or switch to other running commands in the command stack. You can also press the ESC key on your keyboard to open the Switch Command list of running commands at your current cursor position. You can press the ESC key twice to close the current command and expose the next command in the command stack.
HELP
COMMAND TIPS
The Command Tips area of the dialog provides access to the Help document for the command (this document), in addition to any other useful tips that you may need to know while running this command.
The following videos show the use of the Grid Volumes From Boundaries command in a workflow context:
If you would like to provide feedback on the use of the Grid Volumes From Boundaries command or to request enhancements or improvements to the command, please click Reply below.
