Anyone know what could have caused this? This is .dwg drawing from engineer, exploded all the blocks, tried converting all polylines to line strings, played with surface boundary, made sure there were no overlaps, etc. Not sure where to go from here.
Thanks!
max edge length might be it?
This is the largest site i’ve built anything for so didn’t even think to check that… looks like it is indeed the culprit, thank you!!!
Click on the surface and increase the max edge distance setting - you have it set too small and that is causing the holes in your surface. The value needs to be larger than the biggest gap between the contours.
