Is there a command to add prefix or suffix to objects name? I am trying out a new method for girder profile points. So when I shoot out a report I can tell which point is left and which is right of the center of girder. Right now I am having to select all the point on the left and add an L for left and R for right. Is alot of work when you have mutliple spans.
Coming shortly for points - RPS Smart Point Manager - tbat has search and replace for Point IDand Code fields as well as remove or add prefix or suffix as well as methods for naming points in relation to alignment(s) or Reference Line(s) - it can do thousands of ooi ts in relation to hundreds of lines in one pass.
Also new Map Points joins points together with lines in a number of clever ways also
Should be out early this week
Will this be available for TBC v5.6?
Unfortunately not - 5.9 and higher only
