Affix Name Command Improved
Today we enhanced the Affix Name command to have the ability to add or remove Prefix or Suffix values to Point IDs as well as other objects. This allows you to use the Selection Set for the imported Points File to isolate or select the point data that came in from a specific file and add a Prefix or Suffix or remove a prefix or suffix to the Point IDs so that the Point Numbers for different files of data that may be duplicated can be separated into unique IDs.
Awesome work PK
