Add Earthwork Summary Report to Ribbon
I am a new rockpile user. I have downloaded and applied templates recommended during my onboard, which included a very nice upgrade to the ribbon bar. I would like to add the Earthwork Summary Report to my reports section of the Takeoff tab. It doesn’t seem to be a standard command that I can move over as there is no “earthwork summary” command. Any help would be appreciated.
Tony
Anthony,
from your support tab, select Customize Ribbon > Select the Tab you want to populate on the right column > scroll to the report on the left column > use the right arrow to push the command to the tab selected.
Well there’s my issue. I don’t have the Earthwork Summary command that shows in yours. I checked my version and I was still on 2023. I’m downloading the most up to date version right now. Hopefully that will correct my issue. Thanks for the screen shot.
Hey Anthony,
Earthwork Summary was hidden in 2023 due to a bug, if you wanted to run it you would need to do it through the command pane like below and use at your own risk:
the command will not show up as you type like normal but If you type it in as the image shows and hit enter it will run. This is a moot point if you are in the process of upgrading to 2024.
Just as a finisher to the thread, updating to 2024 fixed the issue. Thanks for the help everyone.
