About Smart Takeoff Command
The Smart Takeoff Command is a 100% Rockpile solution for carrying out Site and Highways Takeoffs. Whether you are starting from Plans, Sections or Profiles, the combination of the RPS Smart Feature, Smart Profile and Smart Takeoff commands will lead you to full 3D Earthworks Takeoffs.
Smart Takeoff builds on Smart Feature and Smart Profile, to carry out the following workflows
Existing Ground Workflows
  • Build the Existing Grade Surface model(s)
  • Apply Topsoil Stripping and Demolition Features to create an Adjusted Existing Surface model
  • Define Strata Layers (native material layers) and enter Boring Logs to create Strata Surface Models
Finished Grade Workflows
  • Build the Finished Grade Surface model(s)
  • Apply Subgrade Adjustments and Topsoil / Landsscaping Treatments to create an Adjusted Finished Grade model
Overexcavation Workflows
  • Compute Overexcavation to Existing Surface / Adjusted Existing Grade
  • Compute Overexcavation to Finished Grade Surface / Adjusted Finished Grade
  • Compute Overexcavation to a defined Strata or Surface model +/- a Vertical Adjustment
  • Compute a Hybrid Overexcavation to the Existing and Finished Grade Surfaces
  • Compute Overexcavation and Backfill for Underground Water Detention Systems
Earthworks Reports
  • Generate Earthworks Reports in our integrated Excel Report for
  • Topsoil Stripping and Replacement
  • Subgrade Adjustments
  • Demolition Adjustments
  • Earthworks Cut using Strata Breakouts
  • Earthworks Fill
  • Overexcavation and Structural Backfills
Smart Takeoff provides a fast and accurate way to compute and report Earthworks quantities.
