Wipeout Mask on Blocks
Is it possible to successfully pull of a wipeout mask inside of a block in TBC? In Autocad Civil 3d, I would create a White solid and set it to the back of the block in the actual creation. This was achievable because Draw order was Object Based rather than Layer Based.
I am working on a survey for a class and would like to have my mag nail, as well as others, block mask out the property lines and give it a nice clean look. What is the rule of thumb for this if it already exists.
Thanks in advance for any help!
