3D user defined pipe projected Vertical instead of Horizontal
For the current project, I need to create a post with specific criteria to sit on a drilled caisson. The way I have been able to accomplish this is by creating a point and then a manhole under the pipe utility workflow. However, applying the same process to a user defined pipe ( see image below ), it only works if the pipe is in a horizontal direction. It does not work going vertical. Does anyone know of a better workflow?
I have included a few images of the same item to help show what I am trying to accomplish.
Thank you for any help.
-Jason
Check out our Place Aligned Bocks command - That shows how to do this exact work process - the video can be found on this post
Thank you, This will be a big help.
-Jason
Thank you that worked well. Sorry for pause between posts.
