Trimble.Vce.UI.Client Exception in TBC
We came across this error today with a customer.
Exception Count: 3
Exception Source: Trimble.Vce.UI.Client
Exception Type: System.NullReferenceException
Exception Message: Object reference not set to an instance of an object.
Exception Target Site: so
---- Stack Trace ----
Trimble.Vce.UI.MainFormBase.so(ToolBase a)
Trimble.Vce.UI.Client.DLL : N 01111
Trimble.Vce.UI.MainFormBase.fu(Object a, ToolClickEventArgs b)
Trimble.Vce.UI.Client.DLL : N 00044
Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnToolClick(ToolClickEventArgs e)
Infragistics4.Win.UltraWinToolbars.v22.2.DLL : N 00150
Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FireEvent(ToolbarEventIds id, EventArgs e)
Infragistics4.Win.UltraWinToolbars.v22.2.DLL : N 01622
Infragistics.Win.UltraWinToolbars.ButtonToolUIElement.DoClickProcessing(MouseEventArgs e)
Infragistics4.Win.UltraWinToolbars.v22.2.DLL : N 00643
Infragistics.Win.UltraWinToolbars.ButtonToolUIElement.OnMouseUp(MouseEventArgs e)
Infragistics4.Win.UltraWinToolbars.v22.2.DLL : N 00167
Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
Infragistics4.Win.v22.2.DLL : N 00114
Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
Infragistics4.Win.v22.2.DLL : N 00229
Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
Infragistics4.Win.v22.2.DLL : N 00855
Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.OnMouseUp(MouseEventArgs e)
Infragistics4.Win.UltraWinToolbars.v22.2.DLL : N 00035
System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
System.Windows.Forms.dll : N 00732
System.Windows.Forms.Control.WndProc(Message& m)
System.Windows.Forms.dll : N 01582
System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
System.Windows.Forms.dll : N 00193
Shut down TBC
Go to
           C:\Users\<you>\AppData\Roaming\Trimble\
                  Rename Trimble Business Center -> Trimble Business Center - Old
           C:\Users\<you>\AppData\Local\Trimble\
Restart TBC
This will reset the UI and restore back to Default. Once you sign in with your TID, our tools will show up and you should be good.
