Sta/offset points
When using the Sta/Offset Points command, is it possible for the “code” box to either have a drop-down menu of codes used previously or highlight the last used code when you tab into the code box? Currently, as you progress across a cross-section entering offsets, elevations, and codes; when you tab into the code box you have to manually erase (using backspace or delete) the previous code before entering the next one. If it was highlighted you could just start typing the next entry in, or better yet, when you start typing have the code box provide previously used entries (kinda like excel does).
