I apologize if this has already been brought up. Whenever I go to the Break mode in Smart Edit the Options drop down is always preselected with “Break - Simple” and the Break Mode drop down is always preselected with “Break - Single - Once”. When I go to do a simple break in a line it usually does not complete the function the first time. When I click on the line that I want to break it will highlight in yellow but when I click at a point where I want the break it does nothing. I’ve found that If I go back to the Options drop down and select any other option and click on the line I’m wanting to break then immediately go back to the Options drop down once more and select “Break - Simple” then the function works perfectly. It very well could be something I’m not doing correctly. Has anyone else noticed this? I know there are changes coming to Smart Edit in the next RPS release that may address this. Thanks.
Marc Nagel
