We are starting to build are SI library and are wondering if there is a way to get the different types of SI applied to a surface to show when we make a profile view. We have set the stack up, but can’t see it in the profile or surface slice view.
You would have to create surfaces for each SI. If you just added SI on a surface, use the “create subgrade” command. You will need to select your surface that is used for the SI. Then click the Create Surface at: (which is the SI subgrade) ( Been so long since I used it. ) besure to use the Top of Material in the create surface along. This should create surface for each material.
And once tou have done that you can create a surface profile along your alignment to cut the SI surfaces along the alignment - they will.then show up in the profile view of the alignment.
If you need to shade those areas - you need to use track region command to create a polygon around the area - you can then mKe it a linestring, set it to autoclose property and set a colored fill for the polygon.
Thank you both for the response.
