RPS Settings
Boring Log Settings:
For a full description of the Import Boring Logs command Click Here
This RPS Settings group stores the settings for the Import Boring Log command. The settings include
Borehole radius:
This is the radius of the cylinder created by the import boring logs command that represents the borehole information. The cylinder is colored in a set of material layers based on the strata defined in the boring logs. The colors are defined in the MSI manager for each material found in the boring log.
Borehole transparency:
The borehole cylinders can be set to partially transparent if required. Slide the slide bar between Transparent and Opaque to change the level of transparency.
