Import Boring Logs
- The Import Boring Logs command is part of the RPS Modeling Toolbox.
- The command is located in the Takeoff menu group.
Imports boring log data from a CSV file to create Site (Takeoff) or Corridor boring logs in order to rapidly build strata layers for earthworks quantity purposes.
*The command has been updated to suppress the selection of Reference Surfaces introduced in TBC v5.60, which are an invalid workflow process data source for boring logs.
COMMAND HISTORY
Update Information
COMMAND SHORTCUT
If you are utilizing the RPS Menu Ribbon: CTRL+F9 will open the command.
COMMAND PREREQUISITES
Before you can import boring logs into a project, you will need to complete the following steps:
- Use the Materials and Site Improvement Manager to create the materials that you are defining in the boring logs that you intend to import. These materials should be created in the Earthen category of materials.
- Create an Existing Ground / Original Ground Surface Model that covers all of the locations defined by the boring logs. Note that each boring log should have an Existing Ground elevation that matches the surface that you are creating here. The boring log coordinate and elevation will be added to the Existing Ground surface if there is not already a surface node of the same elevation at that location.
- If you will be using the boring logs for Corridor modeling purposes, then you will need to create an empty surface model for each of the strata that you will be defining in the boring logs and then use the Define Corridor Strata command to define the strata that will be created from the boring logs using the Boring Logs option.
- If you will be using the boring logs for Site Takeoff purposes, then you will need to use the Define Strata command to define the strata surface names and select the materials that lie between the strata surfaces. The strata definition here should match the strata sequence defined for each boring log in the CSV file.
The following video shows how to utilize the Import Boring Logs command for Takeoff purposes:
The Import Boring Logs command dialog looks as follows:
Site Takeoff or Corridor Boring Logs
Not Currently Implemented
Select either the Site Takeoff or Corridor Model radio button to define which type of boring logs are being created from the data to be imported. The definition of the boring log is the same; however, the end use of the data is handled quite differently.
Surface:
Select the Original Ground surface model from the list of surfaces. This is the reference point for the top of each boring log from which depths and thicknesses will be applied.
Note: Reference Surfaces will not be displayed in this list because they are an invalid surface type for this command.
Defined strata list:
This will display the strata list that has been defined in either the Site Takeoff - Define Strata command or the Corridors - Define Corridor Strata command. It shows the strata surface interface on the left and the material that falls below the strata interface on the right. Note that each strata interface is both the bottom of one material and the top of the next material.
Note: All boreholes require the same list of strata, even if a strata layer is absent from a boring log. Where a strata layer is missing from a boring log, you will enter the depth or elevation value the same as the prior strata interface. The thickness value will be 0, and in each case, the missing strata layer will be pinched out at the boring log location.
Boring logs defined by:
The boring logs can be defined using depth values from the defined Original Ground surface, by material layer thickness values, or by elevation values. Select the method that you used to create the CSV file. Note that once you have referenced the CSV file to the command, you can still change the definition method if you selected incorrectly - the graphics will update to reflect the selected method.
Boring logs file name:
Use the file browser to locate and select the boring log .csv file that you wish to import. See the file format definition lower in the Help page for more information. As soon as you have referenced the file, the 3D View of TBC will be updated to give you a preview of the boring log data that it has read from the file.
The boring logs are displayed as cylinders. The cylinders are color-coded to represent the material layers. The color coding for the materials is defined by the materials that you defined in the MSI Manager (Materials and Site Improvement Manager).
The radius and transparency of the boring log cylinders are defined in RPS Settings - you can click the orange R in the Header Bar of the command to open the Settings dialog. Note that the boring log cylinders are only displayed when the Import Boring Logs dialog is open. As soon as another command becomes active, the boring logs will be switched off - they are not permanent objects in the database.
Note: The boring log cylinders are showing you the results of the referenced file, not the boring logs that have already been created in the project.
The boring logs are not committed to the project database until you click Apply or OK. This means that while the command is open and before you click Apply, the borehole data in the project database is not updated, so the strata surfaces will also not be updated until Apply is clicked to commit the changes.
Refresh data button:
You can keep the spreadsheet of boring log data open and make changes to it (change values or add more boreholes). Once you have saved the CSV file, you can click the Refresh data button to update the boring log display in the 3D View.
Overwrite existing boring logs checkbox:
If you have previously imported boring logs and the file to be imported in this process contains boring log numbers that have been created previously, checking this checkbox will allow the imported file to overwrite the boring logs already defined in the project.
If you leave the checkbox unchecked, then the boring log data in the project will be unchanged by the file import process. On completion of the import, you will be given a summary of the boring log data created by the import process.
Layer for new boring logs:
Select a layer on which to place the boring log objects that will be created by the import process.
Boring Log CSV File Format
The CSV file format for the boring log data is as follows:
- Boring Log Number in Cell A.
- Boring Log Northing / Easting in Cell B.
- Boring Log Easting / Northing in Cell C.
- Boring Log Elevation at Existing Ground in Cell D.
Note: The command honors the coordinate order settings defined in the Project Settings of TBC.
The following information depends on how you are entering the strata information, i.e., whether you are entering the strata information using Elevation, Depth, or Thickness values. If we take a simple borehole sequence of Existing - Topsoil - Soil - Clay - Rock, then the values will be entered as follows:
Elevation Values
- Elevation Value of Top of Soil.
- Elevation Value of Top of Rock.
Depth Values
- Depth of Topsoil Value.
- Depth of Soil Value.
Thickness Values
- Thickness of Topsoil Value.
- Thickness of Soil Value.
Note that if a stratum is missing from the boring log, it should be entered with a value that makes its elevation or depth the same as the prior layer above it, or with a 0 thickness, so that it is pinched out at the boring log location.
EXAMPLE DATA FILES
The following files can be used to learn or demonstrate the command in use.
TBC Project File: Test Data Model.vce (247.9 KB)
Boreholes - Depth Based: Boreholes - Depth.csv (804 Bytes)
Boreholes - Elevation Based: Boreholes - Elevations.csv (1.1 KB)
Boreholes - Thickness Based:Boreholes - Thickness.csv (825 Bytes)
INPUTS
Surface:
Select the Original Ground surface that will be used as the reference elevation for the top of each boring log.
Defined Strata:
The command uses the strata previously defined with Define Strata or Define Corridor Strata to determine the required material sequence for the imported boring logs.
Boring Logs Defined By:
Select whether the CSV file defines the boring log strata using Depth, Thickness, or Elevation values.
Boring Logs File Name:
Select the .csv file containing the boring log locations, elevations, and strata information that you wish to import.
Overwrite Existing Boring Logs:
Enable this option if boring logs in the imported file should replace existing boring logs with matching boring log numbers.
Layer for New Boring Logs:
Select the layer on which the imported boring log objects will be placed.
REPORTS
After the import is completed, the command provides a summary of the boring logs created or processed by the import.
The imported boring log data is also used to update or create the applicable strata surfaces for Site Takeoff.
RPS SETTINGS
The Boring Log radius and transparency used for the temporary 3D boring log preview are controlled through RPS Settings.
Use the RPS Settings button in the Header Bar to modify these display settings.
HOT KEYS
U = Unlock
SHIFT M = Pop Up Menu
X = Start Over
Z = Decrement
C = Increment
HEADER BAR COMMANDS
In the Header Bar of the command, you will find quick-access buttons to other commands that you may find useful while running this command.
Header Bar commands include:
- Help - this document access
- RPS Settings
- Takeoff Lines
- Smart Edit
- Adjust Linestring Elevation
- Create Surface
- Add/Remove Surface Members
- MSI Library
- Define Strata
- Create Boring Log
- Rebuild Surface
COMMAND BUTTONS
Apply:
When you click Apply, the .CSV file will be imported and the boreholes will be created. The strata surfaces for Takeoff will be created automatically from the imported boring log data. The command will remain open, allowing you to make changes to the boring log .CSV file and re-import as necessary.
OK:
When you click OK, the .CSV file will be imported and the boreholes will be created. The strata surfaces for Takeoff will be created automatically from the imported boring log data. The command will close on completion.
Cancel:
Closes the command without importing further data.
HELP
The following videos show the use of the Import Boring Logs command in a workflow context:
If you would like to provide feedback on the use of the Import Boring Logs command or to request enhancements or improvements to the command, please click Reply below.
