How/Where can I change the decimal precision and drop the units in creating the point label elevation using the RPS Label Points command?
I’m going to guess its using TBC units setting, try changing them.
Project Settings>Units>Coordinate>Formatting>Elevation
I tried changing it in the TBC setting, it didn’t change on the label.
In the TBC points label command, it follows the setting in the label style manager. I cannot see an equivalent style manager for the RPS tool.
seems to work as Erik stated. you will just have to delete the old label and change decimal and then label again.
The posts here are correct - the text labels are just a text item after they are placed at this time, the decimals are computed at the time of placement, they are not affected if you go and change the settings after the fact - Frank is correct in that you have to undo them and redo them for the decimals to update.
Be careful that you undo and then change the settings and then redo - the Undo will undo a settings change if you do the settings then undo 2x and then redo.
I tried it and it worked. I was also able to drop the units by changing it under the Project Settings>Units>Coordinate>Suffix.
Thanks guys.
Awesome - glad it worked as planned
