RPS Settings
For a full description of the Permit Area Manager command Click Here
Table Settings
The table settings are currently used by the Permit Area Manager and QA Points commands. We envisage many more table creation commands in the future. These settings allow you to control the Text Styles that will be used for the Title text, Header text and Data text of the table. The text style defines the Font, Font Size, Italic, Ground or Sheet units etc. The text styles need to be defined first using the Text Style Manager.
OK
Saves changes to the settings. All settings are global in nature. When you start a new project, the last used RPS Settings will be applied to all commands that utilize the settings.
Cancel
Closes the command without changing the settings.
