In the video below we show you a quick and easy method to georeference your TBC project to match up with Google Earth from the get go.
The process includes
- Creating a measurement in Google Earth between any two points that you can find in the PDF Plans.
- Export that measurement as a KML/KMZ file from Google Earth
- Open a new TBC Project
- Set the Coordinate System for the Project - e.g. Ohio North
- Import the KML/KMZ file of he measurement
- Use PDF Manager in Multipoint mode to georeference the two points in the plan sheet to the ends of the imported measurement baseline
- Check the PDF file against the background map service in TBC to check that it fits and overlays well
Video shows you how
